Creates a new UPM target profile.
| upm_profile_name | Specifies the name of an existing UPM profile. |
N/A.
After configuration, a UPM log target links an EMS filter with a UPM profile. This command creates the UPM log target.
The default configuration for a new log target binds the target to the EMS filter defaultFilter, which is used for all system events. To configure the log target, use the command: configure log target upm {upm_profile_name} filterfilter-name {severity [[severity] {only}]}.
The default status of a new UPM log target is disabled. To enable the log target, use the command: enable log target upm {upm_profile_name}.
To view the log target, use the command: show log configuration target upm {upm_profile_name}.
The following example creates a new UPM log target named testprofile1:
create log target upm testprofile1
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
